Discuss Replacing radiator and valves on open vented system. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a hot water tank, 3 header tanks in the loft and so I am assuming I am on an open vented system. I wish to replace a bathroom radiator with a wider one so will need to extend the existing pipework. I also want to tile around the pipework by drilling the tiles (for a neat finish) and sliding them over the 15mm pipes before attaching the radiator valves.
Can I isolate or turn off the water feed to the radiators to enable me to do this or do I need to drain the entire system? If so, how do I do this?
James
Bung the f and e tank, keeps float valve in natural position. Drain from there. You could hold water in other radiators if you want, I would drain the lot. Do your work. Put correct levels of Inhibitor for amount of radiators you have, neutralise water, if you are pedantic. Fill back up.
Bungee the ball valve up in the small tank and drain the whole system carryout your alterations and tiling dry fit the rad keep the valves closed remove the rad fill flush then fill inhibit vent the system, you can then carry on with the bathroom grouting ect . Kop
Reply to Replacing radiator and valves on open vented system. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
Hi All, I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also...
What pipework changes are needed to replace a conventional open vented gravity boiler to a combi boiler ? Would toilet flush/cisterns need replacing ?
I want to swap a K1 radiator with a P+, the same size on a combi system. Can i turn off both valves, remove the existing radiator, put the new one...
I want to replace a radiator that has a drain valve. Do I need to replace like for like and keep the drain valve in or can I replace with a...
