Discuss Replacing a radiator and Valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All,
I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also need to remove both valves and make the pipes shorter.
Its a gravity fed system and the last radiator in the system , I have a bung kit, i know i can cut the feed pipe into the radiator st there will be a vacuum, but does this also apply to the pipe/valve on the return/drain side ?
Reply to Replacing a radiator and Valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
