Discuss Replacing Standpipe Trap under sink - Dishwasher in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have an issue with the standpipe trap in a 3-year-old flat. This flat came with a fitted dishwasher that has been completely unused for that time – until now...
The weekend before last, I thought maybe it was about time I tested it out running empty – it all worked fine and it drained ok. This weekend I didn’t use it but had used washing machine a fair bit.
Then on Monday morning I noticed standing water in the dishwasher, nearly up to the door. It wasn’t fresh water but looked like previously drained water come back into the machine, slightly sudsy.
Most of the previous week it had been ok – as I’d checked it the next few days after use.
I immediately ran a rinse & drain cycle and all the standing water flowed out again. I then checked the drain hose placement and found that the end of it had been sitting right down in the u bend of the trap.
I’m thinking water had syphoned back into the machine either later in the week, caused by or made worse by the washing machine drain water backflowing.
You will from the photos that the wastepipe seems to have been cut too short when originally installed (I've taken out the drain hose).
My plan is to swap fit a taller standpipe so it’s a few inches below the worktop. I also intend to fit a u-bend bracket to feed the drain hose in at the top.
What was originally fitted was a McAlpine standpipe trap kit, as I can see the labelling. The (too short) standpipe is 40mm diameter, and the u-bend of the trap is fitted to a horizontal 43mm solvent pipe.
I have complete McAlpine replacement trap kit at the ready including the u bend etc.
I'm no plumber and my expertise is pretty limited, so, I was after some advice please:
  1. Can I get away with replacing only the vertical standpipe (with the new seal) into the old u bend connector? Leaving the rest alone?
  2. Or should I replace the whole trap kit with the new one and fit it onto the existing solvent pipe?
And as I’m getting on a bit, the space as awkward, and my eyesight for this type of work isn’t the best….
  1. Is this an easy swap or would I be better to entrust this to the expertise of a plumber !!
Thank you !!
The appliance connected to the stand pipe wouldn’t have siphoned water back as it’s open on the top would have flowed out of the trap first you sure it’s not connected to the sink waste trap ?
Hi Shaun
Yes its now open to the top because I since took out the dishwasher drain hose - ready to swap the pipe.
The dishwasher is powered off and the water supply to it turned off.
The end hose was definitely sat right down in the u bend - there was actually a bit of suction when I freed it, like it had been stuck down against the inside of the pipe.
The washing machine's drain hose is connected to a spigot just below the sink drain - you can almost see that in one of the photos.
Try lifting the dishwasher hose up 6” from the top etc
As is with existing and raise and clip the tube as high as you can go with keeping 6” in the stand pipe
Reply to Replacing Standpipe Trap under sink - Dishwasher in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
