Discuss Replacing Worcester 24si flue terminal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Anton
Hi Guys,
I've been asked to replace a damaged horizontal flue terminal (80/125mm Flue) It's the older all white terminal, so just replacing the terminal spigot isn't an option.
The boiler's on the 1st floor of the house. Horizontal run in the loft with three 1 metre extensions.
The boiler was installed September 2005. (No idea why a vertical flue wasn't installed, I think the cust preferred that option).
Does anyone know what condition the internal flue seals are likely to be in after 9 years ? The flue seals can't be replaced according to Worcester technical.
To replace the terminal I'd need to pull out the last extension through the wall and refit.
Reply to Replacing Worcester 24si flue terminal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
