Rheem - maximum ignition attempt lockout
View the thread, titled "Rheem - maximum ignition attempt lockout" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I am getting a lockout due to “maximum number of ignition attempts”. When I power the unit off and on it seems to work fine but eventually later in the day the lockout occurs. One time I did watch it try to ignite and the igniter turned bright red but no ignition and then lockout code... I cleaned the flame sensor rod with steel wool and continue to get the error code. What would be my next step? Thank you
I don’t know. If it was fuel supply why is it igniting occasionally. Can this be needing a replacement of an igniter assembly? I am. Or calling g a gas technician as all they would do is replace the gas control which is simple to do but before I do that want to know what else I can trouble shoot.
Reply to the thread, titled "Rheem - maximum ignition attempt lockout" which is posted in UK Plumbers Forums on Plumbers Forums.
Oilers,
oz-plumber,
