Discuss RIDGID 370 Bender in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looks interesting , can see bending 28mm in a had bender might be fun. No guides by looks of it?
Very nice bender. But:
a. I believe its obsolete and very difficult to get spares for. I've tried getting new screws for the pipe clamps for mine, but no-one in the UK has any and Ridgid US say its not made any more. Same applies to the guides, which are apparently a special plastic.
b. You really need to use it in a vice, as its very heavy to use hand held, although just about feasible.
c. I'm pretty sure it only does 12, 15, 16, 18 an 22 mm. Being Ridgid its really aimed at the US market, so primarily imperial.
d. If you want a perfect, ripple free, 180 degree bend in 22mm its the one to go for.
Try these people Independent Tool Company..01277 355222 good luck regards Turnpin:wink:
Reply to RIDGID 370 Bender in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
