Discuss Riello RDB Pump Needle (Solenoid) Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
bedlam
Hi
Can anyone tell me how much travel there should be on the "plunger" of the Valve, the one I currently have fitted seems to have virtually none, also should the plunger and stem be able to be separated for cleaning?
Mine can't..... just trying to establish if it is jammed and needs replacing, I can rotate the "plunger" with a needle through the port holes and that is about all
How are you going to set the pump up after you've finished faffing about with it?
Hello Bedlam
Can I ask what has brought you to want to start dismantling the coil stem of an oil pump?
You are, I would guess, inexperienced with these appliances.
These burners/Boilers can be extremely dangerous.
Please get a qualified oil technician/Heating Engineer to reassemble it/ repair and recommission it for you.
Hello Bedlam
I am trying to eliminate a "lock out", I am aware that I cannot set up Pressure, Emissions etc.
although removal of the valve should not affect that - should it?
I just wish to establish how much lateral movement there should be on the "plunger" is all, it rotates in the stem ok
I am also not a numpty 30 years in power plants taught me that
And let them know if its an RDB or Mectron pump they need to bring with them once you have knackered the one you have!!!!
Very high pressure fuel pump and an overall sensitive bit of kit ( The Burner).
It's really not worth trying to DIY.
I'd like to eliminate people who think it's OK to play with things they should not.
Looks like we both will be disappointed.
You've knackered the oil pump for a start. Which makes me question your last sentence.
Although on the brighter side you may just be the statistic that rubber stamps a change in the regulations.
What has brought you to think that it has anything to do with the coil stem? Have you eliminated electrodes, transformer, leads, control box, Coil, motor, photocell, pump performance/pressure using an oil gauge. Have you checked/ replaced the oil nozzle, checked filters on the oil line, checked that sufficient oil is reaching the burner. Have you checked combustion using an analyser?
The above are all tests that should be done before starting to dismantle the coil stem. You are not on the right path to the diagnosis of this lockout and should get someone in who knows what they are doing for both safety and financial reasons.
Forget it...........I have asked 2 reasonable questions and most have gone off on a tangent
without providing an answer, most of which are merely to mock and show off to their mates in this cliquey forum...........
And I have asked you what has brought you to dismantle the coil stem when there are so many things that have not been done before this. You have not replied to this which brings me to conclude that you are playing "pin the tale on the donkey" burner maintenance.
What a tool.
You are not competent to receive an answer.
Then spit dummy when told so.
We had the safety of yourself and family in mind.
You come on here having taken apart a vital component of the burner and without the means to prove it's set up correctly afterwards then get surprised when you get told why you're an idiot?
Your boiler has the ability to kill you, but because you work in a power station you think you are entitled to ignore the levels of competency required to work on the burner.
Actually, you haven't said what it is you do. I'd wager you're the one pushing a broom....
Reply to Riello RDB Pump Needle (Solenoid) Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Hi all, all new to this breakdown life, currently waiting on getting on a training course, so just been relying on technical and instructions...
CJAY40
C
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Does anyone know why an Riello RDB boiler would suddenly start pluming black smoke? Does it have anything to do with the needle valve in the fuel...
5K
problemsolving a electro sterling burner and have narrowed thing down to the stem in the pump that the solenoid should activate- it appears to be...
4K
    • Friendly
  • Locked
Hi, I’m having trouble with my Riello burner. Upon starting the fan motor runs for 10 seconds, then I assume it tries to fire (noise changes)...
8K
