Discuss Roca "The Gap" close coupled , back to wall toilet. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
robertrobinson
Hi , any of you plumbers fitted this toilet? I've done about 5 now and have had leaks with them, cistern doesn't bolt on , just sits on top of pan and two screws at top hold in place , it has the plastic assembly to transfer water from cistern to toilet. Any experiences would be helpful, cheers Robert.
Hi Robert. If you're talking about the gap cleanrim. I have found the pan needs to be fixed to the wall as well as the cistern. Also that the flush pipe cones need to be siliconed as they have a tendency to turn. It's a bit of a weird one!!!
hi Aquablu, thanks for your reply, there is a cone goes into the back of the toilet before flush pipe goes in , there was a second cone, is this used aswell? instructions not to clear on this? cheers robert
From memory I think that flush pipe has a cone top and bottom. It really is a funny design!
Just an update, finally got Roca today , the small flush pipe assembly between toilet and cistern has been troublesome and an updated replacement is available through Roca or supplying merchant (re Roca The Gap clean rim)
Reply to Roca "The Gap" close coupled , back to wall toilet. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
