Discuss Roca vanity unit in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Matt0029
Are roca vanity units a decent standard? Need one with draws and with legs at the front. Roca seem to offer this design.
Yep there decent watch out for the first fix instructions they have many models on and go off product numbers instead of pictures
Thanks, I had a look at one in a show room it seemed to have a service duct at the back. The bottom draw didn't go all the way back so a 32mm pipe could be run behind it. I can't first fix in the wall(without removing tiles etc) it's swapping a basin for a vanity. Any idea if most have this room at the back of the bottom draw? I know the top draw is cut out to take a trap.
The back was open for the ole I did
Agree with Shaun they are of decent quality there is a void for the plumbing but needs some thought to avoid clashing with the draws removing the draws is a must for installation. Regards kop
Thanks I was looking at something like this I can't get the waste in to the void for the plumbing without using a load of bends or removing a load of tiles.
Reply to Roca vanity unit in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON...
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
