Discuss Roman bath nightmare, cannot fix the leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes from the utility room underneathThat waste does look wrong, almost like a basic kitchen sink waste, an unslotted belfast sink waste might be better. It has a larger flange on the surface touching the tiles. Can you get access underneath?
I ended up taking a multi-tool and cutting out the ceiling myself because they just kept on skirting around the problem, guessing when they could've had a proper look insteadI’ve already suggested Belfast waste.
If they can’t figure it out, remove section of ceiling below and it will become obvious.
Might be time to get new plumber and tile guys....
They did say that it was also about getting the right kind of gully??Yes from the utility room underneath
Do you fill that with a combi ?
no, i have a huge tank to make sure I don't run out of waterDo you fill that with a combi ?
it has three RSJ's holding it up and it was constructed with block and brick. Weight was definitely factored in.What's the construction of the floor under the bath like, was it re-enforced, is it just a single layer of chipboard?
It could be that the whole tiled floor area is moving under the weight of water (and occupant(s) ) and opening up a leak.
not unless I run the water and even then you can't see much coz its so tight in thereCan you see the bottom of the waste system from your hole if so add a pic
I think I'll have to give that a goCan you cut a bit more of the ceiling out to gain access?
Reply to Roman bath nightmare, cannot fix the leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
