Discuss Rothenberger bearhug tap wrench in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Reply to Rothenberger bearhug tap wrench in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Never seen that type of ratchet wrench before... https://www.youtube.com/shorts/G9BhDrQPKAU Could be useful, Amazon sell singles of large sizes... https://www.maxrpm.de/BGS-Line-Ratchet-Wrench-Set-6-pcs-BGS-8665?curr=GBP&opi=95576897
Hi, I'm trying replace a basin waste and I cannot get the chrome ring attaching it to the trap undone. It's not a nut so using a wrench with rag is just slipping. I've tried release spray but still no movement. Any suggestions? Cheers, Andy
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
V
Hi all, I'm completely inexperienced at this, but my kitchen taps are ancient, and the water has started dripping. Rather than just change the washer, I want to change the entire thing to a mixer tap that supports two holes. I think I've figured most of it out except for the part where I...
Deleted member 120897
