Discuss Running new gas pipe underground from meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi
I have a job coming up next week where the customer wants the pipe coming off a gas meter and into their utility room. (care home, two meters I'm assuming this new pipe will supply the utility room and the other will do the kitchen but i haven't had a proper look yet)
Anyway the point of the thread is my boss said he wanted me to find out how it will be ok to run the pipe underground and keep it from being damaged. (I will have to lift the tiles up from the ground and it doesn't look as though it will be a major problem.)
Only thing I can suggest it using the yellow gas pipe (MDPE?) as it is strong and will not corrode easily.
Is it possible to run copper underground? I'd say no as it could easily be damaged.
Any suggestions?
Copper wrapped in denso tape, as long as it is at the correct depth then using copper pipe wont be an issue.
Whats the correct depth? Got 50mm in my head.
Tracpipe. No joints and you can run it within the building boundary. Which you can't do with pe.
Galvanised iron and make a shift out of it :smile:
or follow this
Reply to Running new gas pipe underground from meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I wish to add a second boiler to my existing meter. Location 20m away. Underground run. Can l use 32mm yellow pipe with copper tails at each end...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
I have decided to remove the timber floor boards and joists as they are effected by damp and rotting. Was hoping to infill and have slab and...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains...
Hi all, Does anyone have any feedback as to which is best. Running the pipe from the outdoor gas meter to a new boiler on an outside wall or run...
1K
