Discuss Safe to Continue to Use Boiler in the USA area at PlumbersForums.net
Hi, I've had to stop the water at the stop tap due to a leak. Can I continue to use the central heating?
I'm assuming you've turned off the incoming cold water mains stoptap. If so then yes, you can continue using your boiler.
Where is the leak?
Try isolating the incoming supply on boiler. You can use the water in the rest of the house then. Look under boiler and look for brass service valves. Post a pic and we can tell you which one. Might need a screwdriver or a spanner, some switch by hand
Ok all might be not lost ...you have turned. Your cold water supply off...you maybe ok to use your heating ..tell us what system. Expand on why you have had to close your water main off.
We are quite good on here ... centralheatking
Reply to Safe to Continue to Use Boiler in the USA area at PlumbersForums.net
