Discuss Salamander Negative Pump Pulsing issue in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
That's not a plumbers work, maybe handyman or diy.
Not enough info on if a negative head shower is required.
How did you keep costs low on the negative head pump?
Second hand pump
Plumber is the issue and negative head wouldn’t effect / cause the pulsing
I've asked another plumber to quote.
watching plumbers youtube channels they do seem to fit the pumps in the same way so this is a common issue/mistake i'm guessing.
They say the rule of thumb is use a negative head pump if you are getting less than 1Ltr per minute flow, i am getting around 3 Ltr per minute so on that basis i could of gone for a positive head.
Any links to these channels ?
Height of shower and the type of shower is the deciding factor eg pos vs neg
Also neg / universal can be used in both types/ situations
so took it upon myself to swap the Negative pump for a positive one as i wasnt convinced the Negative pump was required or wasnt causing the issue.
Now have a positive pump in place and working perfectly.
Looks like (hopefully) i can avoid the fitting of flanges and expensive plumber refits.
Reply to Salamander Negative Pump Pulsing issue in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi there, We have a standard gravitational system at home and a Salamander pump CT force 30pt is part of the hot water system for the 2nd floor...
T
plumber purchased and installed a salamander shower pump, pump has stopped working after being used for just less than 6 months. Plumber has...
2K
J
Vado celcius 2 way divert bath filler or shower, fed by salamander pump, water pressure and temperature to shower outlet works perfectly well...
