Discuss Salus RT500RF remote programmable room stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
simbo116
Hello all,
Got a problem with a new Salus RT500RF stat.The boiler is coming on during periods when the stat is set to 10 degrees and the room is not that cool.The boiler is a Main Eco 30 combi.I believe that the unit is wired correctly.
Has anyone had similar problems?Any ideas?
The most probable reason is that a neighbour has one and theirs is bringing yours on just change the frequency it shows you how in the instructions
Or take it back and get a decent one. Honeywell. Never had any luck with salus.
100% it's picking someone elses heat settings up. Change the frequency and the problem will be gone. Can't say I've ever had a real problem with Salus. Hope you get it sorted
They are junk. Change it!
AGREED! i've fitted ONE (Grahams own brand, made by Salus) and its been rubbish. Never again. the customer had a power cut and it connected to next doors.
Honeywell all the way.
Sometimes bad is good, good for your bank balance that is, if they lasted forever, there might be less work about. As long as they fail outside of warranty period though. Honeywell in my own house , salus for the customers. lol
Fitted over 50 of these, with only one failure.
On the other hand fitted 8 of the wireless honeywell room stats (dt92e) , going back to faulty stat number 5 tomorrow.
You pay your money, you take your chance
Reply to Salus RT500RF remote programmable room stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
T
I have an Ideal Logic+ 30 combi boiler which was running fine up until a power cut earlier today. Now it's stuck saying "timer or room stat off"...
12K
Hi Just had a new boiler system and smart programmer fitted (salus IT500) Plumber wasn't to sure if the stat was wired correctly as he wasn't...
2K
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hello, my HW is taking longer than expected to heat up and it's getting worse. I can go 10-40 degs after 1.5 hours of only heating HW, whereas I...
