Discuss Salus RT510TX Thermostat help in the USA area at PlumbersForums.net
When my Salus RT510TX controller reaches the set point temperature, it continues to periodically start the boiler for approx 2mins( the flame symbols appears on the screen). When the temp goes above the set point, this stops, but as soon as it drops to the set point, it starts again.
Reply to Salus RT510TX Thermostat help in the USA area at PlumbersForums.net
Hi all, I keep reading about how you should use a smart thermostat. Set it to the temp to want the home to be and hey presto it takes care of...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am...
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
1K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
