Discuss Saniflo Compact 43 toilet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Barbara C
My toilet has been randomly doing a small flush. I've had a visit from a Saniflo engineer who has checked the unit. There is no blockage and it is flushing away correctly.
He has replaced the non return valve and the solenoid valve but this has not solved the problem. There is a very slow trickle of water from the outlet holes inside the bowl which I'm assuming once it has built up (around every 15 mins) it activates the pump.
He doesn't know what to do next and is sending a different engineer tomorrow.
In the meantime does anyone have any ideas what could be the problem?
Thanks in advance
Barbara
Problem is a valve passing inside the toilet cistern, i.e. not the Saniflo unit. The first engineer is probably only equipped to work on Saniflo units not general plumbing.
Reply to Saniflo Compact 43 toilet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
