Discuss Saniflo Compact 43 toilet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
B
Barbara C
My toilet has been randomly doing a small flush. I've had a visit from a Saniflo engineer who has checked the unit. There is no blockage and it is flushing away correctly.
He has replaced the non return valve and the solenoid valve but this has not solved the problem. There is a very slow trickle of water from the outlet holes inside the bowl which I'm assuming once it has built up (around every 15 mins) it activates the pump.
He doesn't know what to do next and is sending a different engineer tomorrow.
In the meantime does anyone have any ideas what could be the problem?
Thanks in advance
Barbara
Problem is a valve passing inside the toilet cistern, i.e. not the Saniflo unit. The first engineer is probably only equipped to work on Saniflo units not general plumbing.
Reply to Saniflo Compact 43 toilet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the...
B
My toilet was slow flushing. I did some research and discovered it needed a new diaphragm washer. I managed to replace that. It now works. But...
My mother has been away on holiday for a few weeks and she has a kitchen mixer tap that has a very slow drip nothing significant - been like that...
Hi there, I'm trying to settle a dispute with my landlord. We recently had a blocked Saniflo toilet (after I'd been a little overzealous with...
Hello, I have had a Saniflo PRO XR for three years. Still under warranty and I put cleaner/descaler every three months. It is used once or twice...
3K
