Discuss Saniflo masticator pumps then stops. Restarts plugging back in in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
T
Travis
Hi there. I have a saniflo pump in my basement. When the toilet is flushed it pumps for a few seconds then stops. If I unplug it and plug it back in it will start again. I tried on a couple different outlets and it was the same. I took the motor out and did not find any debris in the impeller. Any ideas?
Reply to Saniflo masticator pumps then stops. Restarts plugging back in in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
