Discuss Saniflo Saniaccess in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
m4tty
Hi all,
I'm considering buying a Saniflo Saniaccess unit to replace our existing macerator which is dead. These units appear to be much easier to access in situ with separate panels for the macerator and the float (switch?) which is why I'm leaning towards one. I just wondered if anyone has any real world experience or advice on these?
Matt
Wecome to the forum m4tty,
It all depends where you live, if you live near me then the answer is No! Because I might lose £`s unblocking the other sani`s which are harder to get in to.
But if you live nowhere near me then the answer is Yes go for it but be prepared to alter the incoming pipework because the connections are in a different place. By incoming I mean any pipe from the basin and the shower to the box.
Reply to Saniflo Saniaccess in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
The other day, I met up with a friend who has contact with 'green' groups and who hears a lot of alternative technology ideas. Apparently...
4K
  • Locked
Hi everyone, I'm new to the forum and have a couple of questions about Saniflo products:- 1. Are they any good? 2. Are there any cheaper/better...
21K
  • Locked
I'll shortly be having a new boiler installed (probably Glow Worm Ultracom 18hxi or Vaillant Eco Tec Plus 418), together with controls and pump. 3...
2K
p7777m
  • Locked
TL;DR version Getting new combi to replace vented conventional system Q 1) thoughts and opinions of weather compensating programmers? Q 2) Most...
5K
  • Locked
Hi all I've been looking at options for replacing our knackered old gas boiler with Y plan gravity fed central heating / hot water system and...
2K
dennis2011
