Discuss saunier duval ferma f23E in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
saunier duval ferma f23E with a twin pass heat exchanger, so no diverter valve, plate hex etc
however turn hot tap on, boiler fires, the water gets at best luke warm and the rads get hot
run heating till hot, turn tap and the water is a bit hotter but still short of piping hot
also what the heck is a 'reversing valve assembly'
Have you had a look in the book...?
Plumbase Manuals
Starting from cold,,,if you run the hot tap, does the heating flow/return connection start getting hot?
If so,and you can do so, valve the heating flow/return off and see if water temp picks up.
I'm guessing you have checked all the usual suspects i.e gas pressure,water flow rate etc..
yes, classic 'diverter valve has gone' only this boiler doesnt have one
didnt think of that
when you turn the tap on pump comes on, seemed odd for a twin heat exchanger, but as i dont know this boiler very well wasnt sure if it was meant to or not
new boiler
take your point, but i dont like not knowing whats going on
I think the mysterious reversing valve has two functions. When hot tap is opened the diaphragm operates the microswitch assy to switch in the HW control set. I think it also shuts off the CH flow port. I could be wrong..
Reply to saunier duval ferma f23E in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
PSxxxxxx
