Discuss Scale Dispenser. Anyone seen this one? in the USA area at PlumbersForums.net
Hi
Anyone have any idea where you can order cartridges for this scale dispenser?
Jackson Scale Dispenser GB Reg 845496 See attached pics.
Can't find any reference to it anywhere.
Says examine after 6 months, would this be it's first ever change / examine ???
It would be interesting to see the cartridge.
But I also suspect it'll be a case of removing and replace or eliminate the whole thing.
I fear you may be right. But one can live in hope. First in 10 years she thinks. Totally unaware of the maintenance requirement. No water getting to the bathroom taps with a full tank. I was hoping for an empty tank and a stuck ball cock. Not the usual way round I know but it wasn't the case. I have two suspects. The gate valve, which won't move in either drection, and this. Elderly lady living alone. Been without hot water for 2 years. Got to get it sorted one way or another.
Looking at the start of the number for the patent, 5270** that dates back to the 1930's.
Presumably the unit isn't that old, possibly 1950's.
I've tried searching, hence the patent number info, but nothing shows like you said.
Looks like it's going to have to be a delete. While we are at it what's the verdict on bung vs drain the tank? Any thoughts?
Draining the tank might be a problem if she has had no hot water for two years. Any water coming out of the hot tap? If she has a bath shower mixer you could drain the tank through the cold? I worked on a job the other day. Someone had not taken out the old gate valve and fitted a new one below it. Which was not stopping the hot. I drained the tank. Took out both valves. The old one was only open 5mm max. No wonder the flow wasn't very good.
Nothing coming out of both bath taps in the bathroom. There is a trickle coming from the basin taps. I can push a snake down to the gate so there's no obstruction that far. I'm going to replace the gate first. The scale dispenser I'll probably just remove the cartridge for now and convince her to let me replace it later or just delete it. It's going to be a garden hose drain job. I was thinking of a bung but that seems risky to me. But once I can rely on the gate to isolate the tank I can continue with the rest.
Reply to Scale Dispenser. Anyone seen this one? in the USA area at PlumbersForums.net
Hi everyone, I’m new to the forum and joined specifically to try to get an answer to my question. I have an 88yo mother-in-law who is recently...
Hi there, can anybody help? I am trying to buy a replacement toilet flush push button as my current one is broken? However I cannot find the same...
Hi after some advice please regarding a leak in a Miele W3204 washing machine. As per the attached clip I have identified there is a leak at the...
C
Hi there, I have a bath tap that is not producing hot water. Can anyone identify the mixer valve shown in the attached images? It does not look...
Hi there. I have a Cersanit close coupled toilet which as started leaking between the cistern and the bowl when flushed. I've taken the cistern...
