Discuss scottishpower connect in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MakeDo93
I was just wondering if the ScottishPower connect hub (smart meter/wireless thermostat type device, it's the same device as the climote hub) could replace a potterton ep2000 timer control? The boiler itself is a potterton kingfisher II, with a cylinder storage tank, no thermo attached. Would it work with the system?
Reply to scottishpower connect in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
J
We are installing a Tado smart system in our house and want to connect the wireless receiver into the Potterton Titanium boiler. There is...
Deleted member 120897
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
