Discuss Sealing toilet to concealed cistern unit? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
With a toilet fit to a concealed cistern vanity were the front panel slides up if you need access it at later date and fitting
Is it advisable to put a small bead of silicone between were the top of the pan sits against the vanity?
Reply to Sealing toilet to concealed cistern unit? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
