Discuss Second pump in macerator run? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've moved into a house that has a badly installed macerator toilet. After coming out of the Saniflo, the pump runs vertically upwards for a metre or so, then horizontally for 6 or 7 metres - all fine so far - but then under the kitchen sink it goes vertically upwards again for approximately 50cm before connecting with the drain. As I understand it, pumping upwards a second time like this is a really bad idea.
My question is this: is it possible to install a second pump under the sink at the point where it needs to pump upwards for a second time? Or is that just a terrible idea? (It's not practical to simply increase the height of the first vertical run due to the layout of the house).
I should also say - I have absolutely zero plumbing experience, so happy to be shot down (but would be very grateful if this could be done in simple non-technical language!)
Thank you very much for any help!
Welcome to the forums George, shouldn`t really pump in to a pump, as you say it is not correct and it will shorten the life span of the pump, guess the best you can do is to remove any sharp 90 degree elbows and rework the last stage of pipe using 45`s so it is stepping up gradually.
Great, sounds very sensible. Thanks very much for responding... really appreciate it.
I assume you realise it wont be a nice job to change the bend and I suggest not using compression fittings!!!!!
Reply to Second pump in macerator run? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
