Discuss Service valve leaking, odd size in the USA area at PlumbersForums.net
Hi there,
The service valve on the water line, for the cistern, is leaking. Struggling to find a replacement as it seems to be an odd size, 15mm compression fitting and 3/4 inch screw on, on the other side. Anyone know where I can get one? Google searches coming up blank.
https://www.NoLinkingToThis/p/straight-service-valve-15mm-x/58008
straight or angled
Reply to Service valve leaking, odd size in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
