Discuss Service without manufactures instructions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
ajsplumer
Hi guys, I'm a newly qualified gas engineer, and new to the site thought I'd add a post, I'm constantly finding people ask me to service their boiler but they do not have the MI is ther any tricks u guys have to get around this eg finding out wt pressures should be? Cheers ant
As above, i always copy the data plate to my notebook for reference on other jobs.
Yeh, cheers guys probly should of made it a little clearer I ment if the data badge is unreadable or missing, cheers for the responce
www.centralheating.co.uk/boiler-manuals
this site has the majority of boilers manuals and also has the FGA readings that you should expect from boilers which is useful - could print them out if needed
also you can phone manufacturers for MI's they are free as well
with all due respect you have said you are newly qualified, so how do carry out all the safety checks required with out a data badge or MI? this scenario is covered in the IUP and should lead you to classify the appliance as AR, as you CANNOT confirm it is working safely or that the tests you are carrying out are done properly from the right place, please take care, as others have said the data plate gives relevant info but not ALL info, if you are completely comfortable working on an appliance (by having worked on them many many times to learn alll the tests) then you need the MI
Always try and get the mi from the internet etc, have a look through them the night before, it will save you from looking stupid when 25mins later you still havent managed to take off the fire front.
Cheers for the responce website will b usefull, I'm confident to work on appliences that's not realy my issue Im always carefull though to stay on the caution and safety side rarther than take the it will be ok attitude. Cheers
how can you be confident working on an appliance with no data badge or MI, i'm not having a personal dig, just trying to urge caution, there are various gas fires which have particular spillage test requirements, most (and this is where the prob lies) tell you to do a spillage test by running a match across the front of the radiants just inside the hood, to ensure the whole area is clear, however i had one (can't remember the name) in the last place i worked (college) which required the spillage test to be done 50mm in from the right hand side 3mm inside the hood, how on earth can you know this unless you have the MI, the fire looked like any other bog standard gas fire i have seen many times, so without the MI i "could" have been temptted to go with what i know (or think i do) and test by the usual method of running the match across the front of the radiants, please be careful
glass fronted fires different scenario for spillage test?mi,s a must.
I bought a set of 10 cd's off ebay for about a tenner - thousands of manuals. Just looking for a good price on a netbook so I don't have to print out the night before.
Reply to Service without manufactures instructions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
