Discuss servicing tool kit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
woodytheplumber
I have picked up loads of advice from various plumbers and gas fitters over the years and I am after a little bit more, what tools do you guys use that make your job easier for servicing and repairs mainly like the obscure queer tool that you use once a month is what I am meaning thanks in advance
ha ha I do apologise I think you know what I meant no offence meant in anyway shape or form
h
Tiny knipex Cobras.
8mm ring spanner - ideals
10mm vde driver - valliant glow worms Baxi
Decent torch
Angled screwdriver with changeable bits from Poofix. Normally only has a 3mm slotted in it. Handy when you need to remove a clock and its fitted 25mm from worktop........
Mini spanner set , using more and more , 6-14mm
An inch paintbrush with the handle cut off. Just right for getting into dusty fans.
A nut riveter saves having to call baxi and wait for them to repair loose securing nuts on the solo and 100 he style heat exchangers
swivel head ratchet spanners. Britool do a nice set.
Mini knipex cobras as previously suggested.
bent/off set needle nose pliers, I have vice grip ones that work well
loooooong Phillips screwdriver
Schrader valve extension piece
heat sink compound
copper grease
black mamba gloves
nice selection of machine screws
socket set is a must
multi meter
volt pen
dust sheets cut to cover the kitchen work top
stubby screwdrivers
fan oil, wd40 and a rag
magnetic parts dish. (Cheers billy for that idea)
trigger/spray bottle with soapy water in it
blue roll looots of blue roll
Oh and almost forgot I have a few leads about 20cm long with crocodile clips on each end (insulated) well handy to act as bridging wire when fault testing
heat sink compound
copper grease
black mamba gloves
multi meter
volt pen
stubby screwdrivers
What oil do you use for fans?
Reply to servicing tool kit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi, I am in NSW, AU, trying to replace the washers in some shower taps but have not been able to find a tool to undo the nuts holding the handles...
2K
Hi, my 2-handle kitchen mixer tap started dripping cold water. I've got it apart and am waiting for a new cold water, ceramic disc, 1/4 turn...
