Discuss Shock arrest or in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi guys
Heard lads saying about a shock arrestor the other day. I have never fitted one. are they any good, are they used just to stop the noise made (this is the reason they fiitted one) or do they serve another purpose?
Is is there anywhere in particular they need to be fitted on the system?
thanks
before washing machine, inlet valve etc. not fitted one but presumably they work.
normally if the incoming pressure is high, also lack of clips on hammer in combination with ceramic cartridge taps
Stops a combi kicking in for DHW if there is a check valve/water meter fitted
Its asked for in some MIs
If there is a non return valve fitted to the cold main either at the stopcock or water meter you should fit one especially if you fit a plastic boiler. They are just a mini expansion vessel.
A few combi's (even cheap ones) had them inside 25 years ago. Thats progress.
Reply to Shock arrest or in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
