Discuss SHORT unvented indirect cylinders (less than 1200mm tall) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Masood
Hi All,
I need recommendations for short unvented indirect cylinders, please. I need to put one into a loft which has literally about 1250mm clearance. I've found this one:
[DLMURL="http://www.discountedheating.co.uk/shop/acatalog/Telford_Tempest_Indirect_Unvented_Cylinder_170_L.html#TSMI170"]Telford | Telford Tempest Indirect | Unvented Cylinder | 170 Litre Capacity[/DLMURL] but the customer would prefer a bigger capacity (250 litres ideally, 200 would do at a pinch).
Any suggestions please?
Ta,
Masood
200 ltrs 1120 high;
[DLMURL="http://www.discountedheating.co.uk/shop/acatalog/Telford_Tempest_Direct_Unvented_Cylinder_200_L.html#TSMD200"]Telford Cylinders- Telford Tempest - Unvented Cylinder - 200 Litre Capacity[/DLMURL]
Was about to say, get a horizontal one. Never had to fit one myself but I know they're quite a bit more money.
You could put two small ones in twined together but like SimonG I would go for a horizontal one, they are out there if you need help finding let me know. (We have also had specials made in the passed some companies carry the BBA approval to make one off's)
Cheers guys! Appreciate the quick replies. I've only recently done my unvented ticket so am not too familiar with what's available on the market... Thanks again! :eek:)
200 ltrs 1120 high;
That's a direct, snowhead. I need indirect, sadly otherwise it would have been ideal...
EDIT - Actually, they do an indirect version of that, same size. Perfect, you're a star, mate!
Reply to SHORT unvented indirect cylinders (less than 1200mm tall) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future...
Hi All, looking for some advice. I have ARISTON CLASSICO UNVENTED INDIRECT CYLINDER ST1 210 which has corroded at one of the main inlets and is...
Hi, I have recently purchased a cottage with an LPG combi boiler (no mains gas in the area). I intend to replace this with an electric boiler and...
Hi all Need to install a new horizontal indirect unvented hot water tank that's 300L in capacity. Looking for recommendations on best...
3K
Evening all, At risk of blabbing on i'll try keep this short. I recently replaced an old vented hot water system with a unvented system We went...
3K
