Discuss Should a boiler in the bathroom be enclosed in a cupboard? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
capitanpugwash
Hi chaps,
My brother rents out a 2 bedroom terraced house and has a landlords gas safety certificate, but the boiler is on the blink. The plumber went in to do it and as he was fixing it he said that the boiler needs to be enclosed because it is in the bathroom. Is this correct? This had never been mentioned before so I thought I would double check? It has been let like this for 2-3 years. Your help would be much appreciated.
Thanks in advance.
you need to check the actual requirements for the specific boiler, either google the make and model and read the install instructions, or post the details here, room sealed boilers are not banned from bathrooms from a flueing perspective, however steam and condensation can be an issue on the longevity of the boiler so thats why i said best to start with the MI which dictate minimum space between the boiler and a shower/bath
Hi Kirkgas,
Thanks for the response. I've just got onto him and will follow up from there once he finds out what boiler he has fitted.
From the gas side,as said,a room sealed boiler does not need boxing in,however most would say good practice to for reasons as kirkgas mentioned,it is a electrical requirement,there are exceptions and different requirements,depending on size and lay out of bathroom and electrical system installed,also you have to take into account not just the boiler but control operation also
But if property rented out,it would be strongly advisable to box the boiler in,to cover all possibilities and to cover yourselves,as if tenant has a accident the consequences will far out weigh the construction of a cupboard around the unit
imho
Yup, plus 17th edition says 2m from "Zone 1" which is the bath/shower iirc.....
Reply to Should a boiler in the bathroom be enclosed in a cupboard? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hi I've been to a customer today that has a 9 year old baxi duo tec40kw boiler,it runs 20 radiator that all work fine,they have 2 bathrooms and 1...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
