T
Tilernotplumber
Hi all,I need advice please,I renovated a 1970s bungalow some 6yrs ago and done away with all tanks in loft plus hw cylinder and had a local plumber fit a WARMFLOW combi oil 70he , this has been nothing but trouble never breaking down as such just minor leaks meaning having to constantly replace seals/washer also replacing expansion vessel 3 times, however it is now dripping water from the main heat exchanger behind the expansion vessel but I cant locate the source at moment, The boiler is very accessible with flue going straight up through ceiling and roof runs 3xsmallish rads ,5xmedium rads and 1x shower no bath, should I replace boiler and go back to having a tank if so can tank be in loft as plenty of space up there, PS I am no plumber but often do basic plumbing as I often fit wetrooms and refit bathrooms.I am looking for a long term solution which will be more or less reliable cost is not prohibitive in finding a solution.thanks.
