Discuss Shower Advice for low pressure Bungalow in the USA area at PlumbersForums.net
Hi all
Hope Im in the right sub-forum.
I have a gravity fed ( I think) shower. Bungalow has cold water tank in loft and hot water cylinder in a cupboard on ground floor(same level as shower). My gas boiler is an old Glow worm "Normal" boiler, i.e. not a Combi.
I believe my mains pressure is less than 2 bar.
The shower just has a mixer tap with hose coming out.
The pressure of the shower is basically cr4p.
the bathroom itself is nicely tiled etc Id like to sort the shower without having to retile the bathroom at all.
What is the best solution to get better pressure from the shower without getting a new combi boiler?
Some sort of electric or Power shower? Or inline pumps? Hot water tank in loft? Aqualisa shower?
Many thanks all.
Reply to Shower Advice for low pressure Bungalow in the USA area at PlumbersForums.net
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains...
Max Hill
M
