Discuss Shower air lock ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pops 71
Last year I changed a customers existing thermo shower bar valve for a similar type but with a fixed rain head as well as a hand held head,l also changed the existing old pump for a like for like replacement.i didn't alter any of the existing pipe work
I also installed a new pumped digital shower in the new en-suite.Which is working fine !
All worked fine until six months ago when shower & pump stopped working... On inspection it appeared to be some sort of air lock as after I disconnected the fittings to the pump it started working again.....until now....exactly six months on from last time...same thing has happened again !
Customer said that they never had this type of problem before !
Could this be as simple as fitting a couple of air valves ? Or does it sound like a deeper seated problems
Thanks in advance for any replies
Hello. You need to register on the forum and with a username and repost to receive replies
Default Shower air lock ?
How about blocked filters on the pump? Does the pump serve only this shower?
Why would it airlock?
Pump only serves this shower, last time it seemed like air as once I'd disconnected the fittings Fromm the pump it spluttered into action and was then fine.... It just seems weird that it only happens every six months !!
Could it be a gradual build up of air ?
Tell them to lower the handset into the bath to clear the air lock... The pump should hopefully kick on then... Or maybe descale th shower head plus check inlet filters...
So you have a digital pumped in "a new en suite" plus a pumped thermo in another. My guess is both where used at the same time, probably by teenage boys [emoji3] plus other draws on the system at the same time, resulting in emptying the cold water supply which has introduced air. Of course the customer would never tell you this is what happened. If the digital is Aqualisa and plumbed to manufacturers spec, it will be on first draw hot and cold therefore getting new supplies of water first, plus the processor is self priming. Solution is bigger tanks.
Reply to Shower air lock ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi all I had a new bathroom fitted about 4 months ago and all was fine until about a week ago. But now when I turn the lever to run the rain head...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone...
