Discuss Shower cartridge failing after 9 to 12 months in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Mira Silver EV shower cartridge fail.
Can anyone suggest why the cartridge fails after 9 to 12 months (starts to drip). Seal kit doesn’t work, tired of buying new cartridge at £130 a pop.
H/W is from a Combi boiler.
Are you getting generic or genuine Mira cartridges if so I would go back to Mira
Hi Julie…it’s 10 years old but I don’t understand how a new unit would solve it. Apart from the cartridge the rest is just a housing with 2 pipes going into it ?
I know, I have been there myself and the only suggestions Mira could come up with were (1) limescale or (2) the valve body itself has a worn or damaged seating so after a while the cartridge doesn't seal anymore.
I'm still seeing 20plus yr old Mira showers only just starting to fail, but as with all manufacturers the build quality has gone down over the years.
Reply to Shower cartridge failing after 9 to 12 months in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Our master bath shower had two shower heads. One was leaking/dripping so our plumber changed both cartridges since he was already there. That...
DianaCali
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming...
2K
Hi All, So my shower (Mira excel)has just recently started fluctuating in temperature. Typically after about 2 minutes it slowly drops to...
Diyer17111
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
Hi. We have recently had a Mira Atom EV Thermostatic Bar Mixer Shower Valve & Kit installed. However, if someone takes a shower, all is good...
3K
