Discuss Shower flow rate in the USA area at PlumbersForums.net
In summer months do you get a better flow rate from electric showers as the water may come to shower a few degrees warmer??
Or a hotter one
As I understand it the elec shower element operates at a fixed power, the dial for hotter or colder simply lowers or increases the flow rate thereby changing the output temperature.
In winter if the incoming water is cooler then less of it can be heated to a given temperature.
Sound out.thanks
Reply to Shower flow rate in the USA area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
