Discuss Shower inlets not 150mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I am not a plumber at all. I have bought a Mira shower, went to install it but the pipes coming out the wall are closer than 150mm! I know, i should have checked first. Is there any adapters out there that I can buy? I have searched through the web but cannot find anything. Any help is massively appreciated :)
Some showers have Z connecters for this.
Can`t for the life of me see how photos will help this common problem.
The z type connectors are ok but you have to be able to get to back of them to adjust the smaller dimension, if they are behind the tiles ,you may have a problem.
Adjustment 5mm horizontal and 5mm vertical , attached the details
  • 1112482-w2-c-mira-bar-valve-fixing-kit-installation-and-user-guide.pdf
Reply to Shower inlets not 150mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
