Discuss Shower knobs (posts) should they be the other way up (down) in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. Should these shower knobs be facing down instead of up. They seem to foul one another if turned completely.
Reply to Shower knobs (posts) should they be the other way up (down) in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
