Discuss Shower Mixer Flow Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
RG1953
Hi
I have a pumped shower with an Aqualisa shower mixer, Model 400 I think, which until recently was working fine, but now when turning the shower on the pump takes about 15 seconds to start. If the shower is turned off when set to its hottest setting and then turned on again the pump kicks in immediately all other mixer settings take time. The pump is between the mixer and the shower head. Initially I thought it was the pump but it is not obviously not this, cold flow which is from header tank to other taps seems OK, so is this a problem with the mixer, do I need a replacment cartridge at circa £100 or are there other things I should check first.
Reply to Shower Mixer Flow Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
