Discuss Shower mixer tap cartridge replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all
I came to replace the cartridge on my bathroom mixer tap, as thehot tap was leaking, and to get the head cover off there is a hole round the back that you slot an allen key into and undo the grub screw. Once i had unscrewed the grub screw i was hoping the cover would slide off and reveal the cartridge to replace but the cover wont come off! I dont know whether there is a special way to get them off or whether it has just seized on. I tried some WD40 but didnt seem to do the trick.
Ive hopefully uploaded a picture of the tap.
Any advice will be a great help.
thanks
It does come off. However, it will be calcified on so rock it back & forth gently but firmly pulling upwards as you go.
Sadly, this will only be your first hurdle. More is to come as the taps are located where they are - hopefully not ;) #TestOfYourMettle
Reply to Shower mixer tap cartridge replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
