Discuss Shower mixer tap cartridge replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all
I came to replace the cartridge on my bathroom mixer tap, as thehot tap was leaking, and to get the head cover off there is a hole round the back that you slot an allen key into and undo the grub screw. Once i had unscrewed the grub screw i was hoping the cover would slide off and reveal the cartridge to replace but the cover wont come off! I dont know whether there is a special way to get them off or whether it has just seized on. I tried some WD40 but didnt seem to do the trick.
Ive hopefully uploaded a picture of the tap.
Any advice will be a great help.
thanks
It does come off. However, it will be calcified on so rock it back & forth gently but firmly pulling upwards as you go.
Sadly, this will only be your first hurdle. More is to come as the taps are located where they are - hopefully not ;) #TestOfYourMettle
Reply to Shower mixer tap cartridge replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
