Discuss Shower/Mixer tap diverter valve issue. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can someone advise me please. On this mixer tap, when it runs the bath taps, all is fine, when the handle is switched to shower, it spurts slightly from the diverter valve. I've taken the handle off, as per photo....is this a simple case of, removing the valve somehow and replacing a washer,? Or is the whole thing broken? Thanks in advance.
it probably has some orings inside. try to remove it and see if you can change them. never had one out as we usually replace tap when to get to this age. good luck :)
Welcome! Did you fix your issue?
Hi. I haven't tried yet to be honest. As the previous reply wasn't too sure. I mainly wanted to know if anyone has ever taken one of these off and fixed a leak with a new washer etc, but it appears maybe most people would just replace the taps.
Ah well let us know how you get on :)
Reply to Shower/Mixer tap diverter valve issue. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I thought I'd share my experience of dealing with Aqualisa about their Quartz Digital Diverter. When selecting the slider rail handset the...
I have a traditional style bath tap with shower attachment via a diverter. The lever no longer moves, and so I managed to unscrew the lever arm...
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
