Discuss Shower panels. How to fill gaps around pipe holes that are too large in the USA area at PlumbersForums.net
So. I have managed to fit shower panels directly over tiles. My issue however is I had to cut the shower panels more than I had liked around where the water pipes come in due to the metal fixings that attached them to the wall. This now means when I screw the pipe collars back over the pipes, I’m some parts there is a 15.5-20mm gap. I don’t really want to try and bridge the gap just by siliconing it’s as would look shoddy. Any ideas? I have tried to find other chrome pipe collars that fit a 26mm pipe, but have a diameter of 80-100mm that are flat rather than cone shaped ,not higher than 10mm but am struggling but this would be ideal as would branch the gap and allow me to then silicone around edges.
You were supposed to remove the fast fix brackets before you installed the board
Only option now is to buy a new board and remove the old one
Post a picture please let's see what you've done ?? It sounds like it's a new board maybe needed longer you leave it the harder it will be.
Reply to Shower panels. How to fill gaps around pipe holes that are too large in the USA area at PlumbersForums.net
