Discuss Shower Pumps: Monsoon vs Salamander vs Grundfos? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys!
I'm getting a dead shower pump replaced with a new one.
It's for a 2010 Aqualux Crysta steam cabin and the requirements are a Negative head twin impeller pump, either 2 or 3 bar. (only the shower will be hooked up)
Water pressure isn't great in the house, so a negative/universal head one required.
My plumber suggested Monsoon, Grundfos, or Salamander
I'm trying to buy locally from Plumbing suppliers, and narrowed the list down to the supported models
Stuart Turner Monsoon Twin Pump 2 Bar or 3 Bar
Salamander CT Force Twin Pump 2 Bar or 3 Bar
Grundfos Amazon Universal Twin STN2.0 Bar or 3 Bar
Basically -which of the 3 make the better pumps - Stuart Turner, Salamander, Grundfos.
My last one burned out after a few years of moderate use, so i'd like any feedback you have on the brands regarding their reliability.
Grundfos and their spec look good and can be bought at a very reasonable cost online.
I installed one a year ago and it impressed me.
No idea of their reliability.
I use Stuart and Turner pumps and they are superb, but expensive.
Note you need all pumps to be installed properly so they give good life
Definitely the ST monsoon, but as stated above it must be fitted correctly for long life. I’ve just replaced a 3bar one I fitted 18 years ago, annoying the inlets/outlets have changed a bit since then so had to alter pipework a tad. Hence new one is on a 4” concrete block “to improve sound insulation “ ( and allow me to easily shorten pipes rather than have to lengthen them)
Reply to Shower Pumps: Monsoon vs Salamander vs Grundfos? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi All Just looking for some advice on which Exposed Thermostatic Mixer Shower (Bar Shower) would go well with the Shower Pump i'm getting...
I have a negative head twin impeller Stuart Turner pump feeding hot and cold to three showers, one bath, plus hot to three basin's from my gravity...
Hi there, We have a standard gravitational system at home and a Salamander pump CT force 30pt is part of the hot water system for the 2nd floor...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
