Discuss Shower size help/advice (DIY) in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all
Fitted a new shower at home and the shower arm extends too far out for the screen (pics attached) a lot of water escapes out of the shower and on to the floor. Is there a replaceable shower arm that I can purchase and if so what should I search to find this? Or is just a case of buying a larger screen?
Thanks a lot!
larger screen ideally the full length of the tray
What are the dimensions involved?
And is it a shower tray with three sides tiled and therefore just one side to screen off.
Assuming it is three sides tiled.
1) a full width sliding door to full enclose area, this will be water tight.
2) a piece of glass as wide as possible to allow access, and then fit a flapper panel to this glass to extend it further - if this is left at an angle when showering it will contain most of the water , but it won’t be water tight .
Reply to Shower size help/advice (DIY) in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
