Discuss Shower trap - sewer smells in the Ireland area at PlumbersForums.net
Hi Guys,
Some advice please on sewer smells coming from the shower trap. I suspect the water level in the trap is not high enough to prevent smelly air coming back. See photos. From the waste pipe arrangement, I don’t see how you can create a water seal when the top of the waste pipe is above the water level?
Any advice much appreciated
Thanks for the diagram. No tube fitted :oops: and that no doubt is the cause of the problem, as I can see the tube creates a type of “u-bend”. Next questiion is, where can I source a replacement tube? The trap is about 25 years old.
[automerge]1606046666[/automerge]
I think this is the part avavailble from Plumbers Mate
thanks Shaun for your help
stick a tape measure or ruler in until it touches the bottom of the trap is it around 160mm-165mm from the bottom to the top of the tray ?
Reply to Shower trap - sewer smells in the Ireland area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
