Discuss Shower valve elbows and flow rate in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Im planning on how to fit a concealed shower valve into a paramount wall which has a narrow cavity depth(35mm)
Luckily the rear face of the wall is in the hw cylinder cupboard so i plan to have part of the valve coming through to the cupboard then boxing it in.
If i do this the position of the inlet and out let valves will be partly blocked by the plasterboard board so i was thinking could use a couple of 90 degree elbows separated by short section of pipe in a sort of z shape to clear the obstruction
The question ive got is will using multiple bends un close range have a big impact on the flow rate?
Its a gravity fed system so I'll be using a shower pump (not specced and bought yet)
Why not use an exposed valve ?
Depending on what your planning why not remove the plaster board and cardboard and install some 3x2 or 4x2 and glue to the existing plasterboard ?
I recently fitted an ibox in a paramount wall (80mm minimum depth).
I cut away a section of the plasterboard so I could turn the elbows to 45 degrees and pulled a bend in 22mm copper to suit this- this is less restrictive than your suggestion.
However if you use a suitable pump, what you propose will be fine.
I cut away plasterboard and then fitted a plywood plate on the cupboard side of the wall to strengthen it and give me something to screw the valve to.
It was a bit fiddly but worked well, just put a removable box to protect the valve, but left pipework exposed so any potential problems would show themselves in the future- not all hidden away, and it gave easy access for some full bore lever valves.
Reply to Shower valve elbows and flow rate in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
