Discuss Shower waste hits joist slightly in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi folks,
Got a cracking deal on a stone resin shower tray but unfortunely it hits the joist slightly.
https://i.*********/AFYfZDm.png
The joist is around 3.25" wide and 6.75" tall, and I would have to cut out a vertical notch from the joist of 1.15" (at the max, it will probably be less than this) for it to fit.
Would this be acceptable, or shoud I consider a different approach?
Thank you.
You will significantly weaken the joist with your notch. You'd need to ask a structural engineer whether this is an issue in your circumstances. If so, it's usually possible to reinforce joists by 'sistering' them but you need to think about how waterproof your method will be in the event of a leak. The structural engineer will be able to specify materials and methods.
You could do that but you will need to sister the timber to the nearest span / load point
Reply to Shower waste hits joist slightly in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just paint tanking slurry? Thanks in anticipation, best regards Staggers
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
