Discuss simple plumbing question re water turn off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lockwise123
hi
many years ago i put in a mira 88 exposed valve (used in conjunction with my old back boiler setup) - recently i had a combi boiler installed and the mira 88 is not great but it seems mira 415 is best suited to a combi boiler setup.
anyway, thats neither here nor there. In order to remove old 88 unit i of course have to switch off water to it. Alas although the cold feed to the mira has it's own stop valve, the hot pipe to it doesnt.
So is it ok to turn off the cold water at the mains then drain shower until water flow stops? But more importantly, when i turn on the mains supply again do I need to do anything to the boiler or will the water find it's own way thru it etc?
thanks
thanks
so in short.....turn off mains, turn off combi, drain shower head, remove and refit new shower valve, turn on mains, allow water to flow for a while, turn on combi?
yes you can turn the boiler back on once you have cleared the air out the hot taps / showers etc
but
turn boiler off
turn mains off
drain shower head,
turn on mains,
clear air
turn boiler back on
thanks guys
i might take the opportunity once water is off and drained to pop a valve on the hot pipe leading to shower (it's plastic pipe).
Reply to simple plumbing question re water turn off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
