Discuss Single/Double/NRV Check Valves Query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good morning,
I have a query about single check valves/double check valves/non return valves and their purpose.
I moved into a flat built in the 1960s and I think the bathroom was last upgraded around 2007 perhaps even before.
I am going to get it completely redone next week (new suite/ taps etc) and want to have single check valves installed in the bathtub water pipes and the basin pipes because the pipes don't even have isolation valves or anything.
Could someone advise if check valves of any kind are mandatory to have installed and if so their purpose and how many are necessary. My main concern is ensuring their are no back flow water issues, fresh water is always flowing in the correct direction and would appreciate advice from experts so that I can then inform the workmen what extras I need for the bathroom revamp, thank you.
Check valves are if I recall correctly, for situations where backflow (a flow unintentional of original direction) may occur, an example is where it's not possible for a shower head to maintain an air gap above the bath spillover level. Does this make sense?
You appear to be in the UK. As long as the bathroom is being installed to current Building and Water Regulations appropriate measures are standard not extras.
If you are designing the bathroom yourself there is no substitute for studying and understanding the applicable Building and Water Regulations, which are available on line. These cover the necessary backflow and cross-flow prevention measures.
Arrow Valves have some useful guides to the Water Regulations:
that cover washrooms, shower / bath / bidet, isolating valves, notification, etc.
If in doubt, consult a qualified plumber, fixing mistakes after the bathroom has been finished can be painfully expensive.
Thank you for the advise and yes I am in the UK. I am not designing the bathroom myself but a family owned business is going to do a complete installation next week, I was just curious if I had to ask the workmen to install check valves or would everything comply in meeting Building and Water regulations because the current pipes don't have any valves or even isolation valves in them.
[automerge]1569061792[/automerge]
Generally non return valves, single check & double check valves are not fitted in bathroom or shower rooms. The risk is to prevent dirty water backflow into the cold water drinking supply. This generally is not a risk in a bathroom as the greywater in the bath is below the taps and even if you have a deck mixer leaving the shower head in the bath water will not back siphon as the supply will be on or shut off. Same applies to showers as the risk is even less. However I can see a rare situation in multi occupancy buildings eg tower blocks where a flat at high level might eg due to being a void or poorly maintained might back siphon
but the chances are rare. I suppose I could quote chapter and verse of this aspect of wras but above is an honest working interpretation
others might add ...so dont worry....centralheatking
Thank you I appreciate your advice very much. I used to live in a multi storey tower block and the water supply did have siphoning issues.
Now I live on the 3rd floor of a 3 storey flat and am just trying to be cautious and doubt I will need valves and don't want to pay for anything which isn't required. Lastly would the kitchen sink ever need a valve attached to the pipework?
If the kitchen sink isn’t a balanced supply, and a mixer tap then it’s a fluid category risk 2 and would need single check valves.
A balanced supply would be a mains fed cold with a combi boiler of equal pressure.
I’d always fit a double check valve on a mixer tap/shower where hot and cold water may mix. My understanding is this dates from vented tanks in lofts etc and possible legionella risk.
What is your hot water system
If it’s gravity hot water then a single or double check is required on the hot to stop the cold overpowering the hot and back flowing
If it’s mains pressure eg same as cold water then there is no backflow risk so you don’t need to allow for anything unless your taps are below the spill level
As for iso valves always fit them on toilets basins and kitchen sinks
Type of iso full bore iso valves are the best
Don’t fit the cheap ones as they have a smaller internal dia around 10mm
Eg
Small dia
Isolating Valve 15mm 10 Pack
Full bore
https://www.NoLinkingToThis/p/full-bore-isolating-valve-15mm/46860
Reply to Single/Double/NRV Check Valves Query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
